ralliart_ray
- Feb 10, 2001
Can the switch be placed "in front" of the router?
I think can.... but i havent try that suggestion...
I understand new HDB BTO flats come with structured data cabling.
Anyone able to share their fiber network schematic?
As in how you wire up your home with or without the patch points provided?
I want to understand where the Fiber termination point will be and where do you install your modem, router, etc.
Tks.
can someone shine some light on this.
if say i convert all the telephone points in my bto to data point.
how do i activated all the data point with signal?
since effectively there can only be one lan cable coming out from the ont, to be plug into just one data point.
Just to share my set up.
1. Stick a piece of wood to the wall by using Maxbond.
2. Wall mount everything on the wood, less the router which I've DIY a shelf.
3. Run cables "as neat as possible" ... try lah.
Oh, I didn't get flooring from HDB, so I ran my own CAT 6 cables to all the rooms before the contractor lay cement & tiles. Then I terminated them to the network switch.
I did add an AP in the MBR so that I've wifi coverage throughout the whole unit.
In short, TP -> ONT -> Router -> Switch -> Rooms.
Can i use this set up?
TP - ONT - Switch - Datapoint.
Then stock router from starhub and purchase another router plug into living hall and room datapoint?
why cannot ah? for starhub case scenario they giving me a ont + a purely router dlink 868l. i can connect ont to the only datapoint and place router outside no?
Hello everyone,
Would like to tap on the experience of the people here.
My current place does not have all these new utility boxes that house the fibre network stuff. I did not install the fibre point when they first came around. But i think it's time to rethink my home network but have a couple of questions.
1) Should i do my renovation first before engaging the fibre guys to install the fibre point?
2) Or should i go ahead with the fibre point termination point before renoavtion
3) I have old phone jacks in my place and don't use them. Was planning to use them for network points.
I would like to keep the cables hidden and not have any exposed trunking / casing if possible. If i want to go this route, should i do point 1 first, inform the interior designer that they should provision for the fibre guys to pull the cable to my designated point?
i will suggest to go ahead with renovation first, because there are cases reported here that contractors damaged the fibre optic cables in the process of renovation..
the termination point can be installed with a surface trunking and minimal drilling, the person installing the termination point will discuss with you to make sure the most minimal damage is done to your interior design. but of cos, don't expect everything to be impeccable, but i guess your interior designer can advise you more on this..
whether or not the existing phone jacks can be converted to rj45 depends on the type of cable used. if its a newly bought first hand house, then likely. if its a resale flat or apartment, then you gotta check..
after you missed the appointment to install the TP free of charge, you have to sign up for a fibre plan with the ISP first before they can engage NLT to install the TP for you. some high end fibre plans will come with free installation, while some low end plans don't. do your research first yeah?![]()
Any one has experience for the network plan for Hdb manaionette
Dear all, I am doing my Reno soon. I plan to convert living room and bedrooms points to data ports. There is smth that is troubling me.
I plan to get the asus ac88. This ac88 router will be placed inside the utility box. How does it affect the wifi speed in a enclosed area? I hope to get a good speed since I'm spending on a high end router. Any speed to share with the router inside the utility box?
Any Bros here have managed to place the router just outside the utility box with all the cables nicely concealed ? There will be quite number of cables, (power, ont, and 4 x lan cables)
