Any bro here has a dead Asus M4A785-M motherboard, can give me the I/O plate? Went to SLS to hunt but can't find.
Factor shipping & conversion rate, it will cost me over $20 for just a I/O port.
something i always wonder, How on earth do people lose their i/o plate.
I suggest you keep the money, take a cardboard and cut out the ports and ta-da. Solves your issue
I DIYed, lasercut i/o shield using 1mm thick acrylic.
Whoa, won't this be more expensive than ebaying the I/O plate?
I was about to say if can 3D print the I/O plate, but that sounded too expensive too![]()
This motherboard was given to me w/o the i/o plate. Since it is still working, I rather use it then let it waste.
Cannot use w/o IO plate meh?
air dust all go inhe used the board but at the back got longkangair dust all go in
I/O cover can laser cut or not, or must 3D print?Lasercut is not as expensive as 3D printing which need at least 2 hours for this shape and size. Lasercut can do it within 15 minutes if you already drawn the layout in either cdr or dxf format. The time taken is almost the same as cutting 120mm fan grill.![]()
