[Official] Apple iPhone 6S/6S Plus Discussions
*adiBOY
On iOS 9.3 Beta now. They have included blue light reduction setting. Works like a charm. Charging bug is fixed too. Lag is not apparent and overall smoother UI. A very major upgrade by Apple.
kopi22
Was using the official UFM1003 app via wifi and the streaming stops some time after the screen is locked. But no such issues when on mobile network. Tried other radio streaming app and works fine while on wifi. Strange. Anyone encountered similar problem before??
*adiBOY
Public Beta for iOS 9.3 is out. For those who wants to try it, please download the iOS Beta Confoguration profile beforehand and check for update. The beta is very stable so far. All the apps work as intended. Overall the phone feels faster and the UI is more smoother.
Sherra
Hi guys.
Nowadays if my singtel set iPhone is spoilt, do I still go back to comcentre for warranty or where?
swgj86
Hi guys.
go to service centre. wheelock or plaza sing.
went to both places to service my apple watch b4.
weng
Duno if this has been posted before...
My sis bought 6s+ recently, and was underwhelmed with the vibration mode.
When vibration mode is on and calls/msgs coming in:
- put flat on table (both front and back), totally zero sound and zero vibration, = totally miss it unless you are looking at the phone and know that a call/msg is coming in.
- put in pocket (not tight), totally missed the vibration as well.
- feel the left, right and bottom sides, vibration is STRONG.
- feel the front (screen), back and top side, zero vibration.
Online feedback seems to be mixed. For certain there is no smoke without fire, and there are indeed pple complaining about missing calls/msgs not because cannot hear (some "righteous" pple are critical of it), but rather cannot feel. However there are also pple who preferred the taptic engine vibration (so that means they can feel it?)... so I duno whether there is really a defect in my sis's phone or somehow just gotta adapt. But how to adapt when really can't feel or hear anything unless one of the left/right/bottom side is in contact with your body or some object that will rattle upon "transferring of vibration energy"? :s13:
szeli
e new Taptic Engine definitely feels different from e past vibration. if u really feel it's bad, just bring down to service center. I think they should have some tests to determine if yrs is normal or bad...
XasakuraX
ehh y apps install so slow? i c all stuck at loading, paused all but one still nt moving...
dawntime
Restart phone. Mine also like that. More and more issues.
You might also spot a trend with regards to stopping and resuming downloads by tapping on them, will result in the progressive circle notion to be always in the same few positions like 1/3 or 2/3
derrickgoh
Generic suggestion. Don't install too many apps. Seriously. My own rule of thumb is if I've not used any app at all for the last 6 months, I will delete it. Anyway can always download again. You'll be surprised to know that too many apps can cause issues.
