WhiteHunter
- Sep 13, 2012
Yes even if you feel it is expensive, just tell yourself you are practically buy a part of the arcade machine, just put that stick down on the table and play street fighter, guarantee you would feel like it controls like the arcade machine.
You buy a cheap hori mini stick is too small and cramped and moves around, no arcade feel, later you have to upgrade. Spend even more money.
Sent from Landed Property using GAGT
if you pro, use ps4 controller also can play.
