Any colour themes in particular?
His budget and mITX nature cannot have colour theme liao...
What are colour themes?
This is silvery-white and black theme:
Just sharing my planned build:
i5-6600K
Gigabyte GA-Z170N-Gaming5
2x 8GB DDR4
Samsung EVO 850 500GB M.2
Silverstone SX500-LG
Silverstone SG13
Re-using:
MSI GTX760
Corsair H60
HDD etc
I think within $2000 if everything new too. Can consider and modify from there![]()
you reuse gpu but for TS case I think better to get new gpuJust sharing my planned build:
i5-6600K
2x 8GB DDR4
Silverstone SG13
Re-using:
MSI GTX760
Corsair H60
HDD etc
Hey guys!
Thanks for all the comments and recommendations.
How about if I can up my budget to $2.5k?
I don't need colour theme, led lights, overclock. But I do like a mITX case with side panel window so I can see through.
As I won't be getting it so fast, maybe like three weeks later.
any particular case in mine? cause some case got restriction, especially for mAtx/Itx form factor unless you are going for atx case, than you would not need to restrict yourself to a mAtx board which is normally a bit more exp.
Do you need WiFi btw?
With $2.5K, GTX 980 Ti build will not be an issue.
