Motherboard uplorry?
aoptionwriter
Have a close look to examine the circuit on board. If you see a burnt mark or scratch, then you have a problem
majora
Hi all, I managed to replace my old mobo with a new one, everything is up and running :)
Just one question, I thought when I change to a new mobo, I have to reinstall Windows? It seemed that I can still go to my desktop as per normal as if I didn change any hardware at all..
Should I just use as per normal? or do I need to download some Drivers online for my mobo?
yusoffb01
Don't need reinstall windows if same chipset
If same model MOBO no need to reinstall Windows.
majora
I changed from gigabyte to asrock can resume from hibernation after reassembling
Mine opposite of yours, mine is from ASRock to gigabyte. Alright then.. And my old mobo will be back after around 1-2month..:s22:
yknyong1
What happened: Pc won't start up.
-No beep sound after turning on/restarting the PC
-remove ram and restart, no beep
-reinsert ram to different slot, no beep
-remove graphic card, no beep,
I think the motherboard is spoilt, what do u guys think?
Try reseat CPU
yknyong1
So it was the mobo?
