Monitor or GFX problem? HELP~~
rejuvienate
Hi guys, so my monitor started having these two blue thick vertical lines and afterwards the screen just goes black.
I have tried unplugging all the cables and the GPU and re-inserting back in but to no avail. Is the graphics card the issue here or issit my monitor? I don't have an extra monitor or GPU to do troubleshooting tho..
GPU - powercolor 7950 3gb pcs plus
Monitor - Dell U2312hm 23" IPS
Rig bought in 2013.
ZrE0_Cha0s
do u have a spare cable to change and test it?
do u have a onboard gpu to test it?
do u have a spare monitor to test it?
best hope its cable issues.
worst is gpu
but monitor i think is fine, since u can get a ips monitor cheap nowadays.
rejuvienate
worst is gpu
Oh ok managed to use onboard graphics to test, and the lines were gone! Unfortunately warranty expired already.. means now need to hunt for new GPU~ :)
ZrE0_Cha0s
to get the similar performance gpu can consider getting GTX 1060 or rx 480/
tigerwoods
powercolor cards always die just after 3 yrs, my 7850 also like that.
