1.8k budget help
singupingu
550w is more than enough. I'm using cm elite v2 (no 80+ rate) and don't see the problem. Lol
Nothing to downgrade anymore for your rig.
For cooler, cryorig h7 seems okay if you like tower kind cooler. Otherwise the c7 would work fine as it is low profile and your processor is non-k
Sent from Overpowered Phone Mark III using GAGT
PolyInHelp
Thanks guys! Is there any B series motherboard to recommend based on the below rig? Will get it over the weekends this week.
What would be the difference between the H series and the B series? Wanna future proof it as much as I can with the budget of 1.8k :/
i5 6600 + MSI H110M PRO VHL
Kingston Value RAM 2x8GB
Corsair CX 650W
Palit GTX 1070 SUper Jetstream 8GB
Tecware F3
Crucial MX300 750GB
WD Blue 1TB
Dell 24" monitor
PolyInHelp
Confirmed parts to be getting. Need some light to comment on any? Sorry for the trouble caused :/
i5 6600 + MSI B150A Gaming Pro
Corsair CX 650W (maybe 550w?)
Tecware F3
Crucial MX300 750GB
WD Blue 1TB
BenQ XL2430T 24"
To final double check, would all this part work? Any bottleneck issue? And would it works wonder? My budget got increased to roughly 2k. That's why I got the 144Hz monitor.
singupingu
It's balanced. No worries.
Psu if you want can get Superflower leadex 550w gold.
Since budget increased, you want to spend on higher specs or just accessories/aesthetic?
For led, you can get deepcool 350 rgb led. I put mine at top and right hand side (behind front panel). Got it from lazada tech dynamic for 30 bucks only.
PolyInHelp
Hey guys. I just got to know that the mobo I picked (MSI B150A Gaming Pro) is a ATX board and the case which I'm getting (TecWare F3) supports Standard iTX / mATX motherboards
Would it still fit in? Considering that the GPU I've bought was Palit gtx1070 super jetstream.
ZrE0_Cha0s
nope, it cant fit. and u have to a ATX case like tecware alpha, which is more than enough to fit all the things u need.
