RawBeef
- Mar 15, 2017
MSI GL62 7QF.
Been using this laptop for a year or so and having this issue for slightly more than half a year. Can't take it anymore, so im seeking help
Specs as follow:
https://imgur.com/oDKknlj
Hard-Drive in-depth:
https://imgur.com/pzqhdKk
From the moment my laptop boots, the disk hits 100%. The tasks are things like System, Symantec Service Framework, and many different service hosts such as superfetch. (I've disabled those that i can to no avail.)
Example:
https://imgur.com/a/oXJJNJn
I suspect its my HDD issue or maybe because my laptop does not have a SSD in it. Would getting a SSD with high read write speed fix this issue? or is there something more?
/Edit/:
Standard troubleshooting found on g00gle have been done.
- Disabling various services.
- Using CMD to check for bad sectors / fix it using some commands.
- Full system scan
- Clean format.
Thank you!
Specs as follow:
Example:
/Edit/:
- Full system scan
- Clean format.
Thank you!
