10Gbps routers consume more power than a Fridge!
tsammyc
I've been running at 10Gbps network since around 2018 to edit 4K video off a NAS, but usually turn off all the 10Gbe equipment because of the extreme heat that they produce. So on a day to day basis I run max 2.5Gbps, unless editing video, and all the equipment remains cool. With all the 10Gbps routers being sold now with multi Gig plans, I was wondering how much power they consume. My three BE230s and one HU710 run fairly warm. The Dongknows website actually measure power consumption of the routers he tests over a 24 hour period. So I compiled all this tested routers, divide the results by 24 (since he measures over 24 hours) to get the W that they consume and reproduce that in a table below:
Asus BE88U 14.2W
Asus BE86U 11.7W
Asus BE96U 15.6W
Asus BE98Pro 23.3W
Asus BT8 11.3W
Asus BT10 15W
Asus BT16 22W
TP-Link BE230 8.1W
TP-Link BE550 12.9W
TP-Link BE800 23.5W
TP-Link GE800 24.4W
Deco BE25 8.1W
Deco BE85 20.2W
Deco BE95 22.3W
Netgear RS200 6.7W
Netgear RS300 10.4W
Netgear RS700S 15.6W
Eero Max 7 18.8W
Velop Pro 7 9.8W
As you can see, there is quite a difference with power consumption. Routers with 10Gbps ports consume much more power than those with 2.5Gbps ports. The most power hungry router is the TP-Link Archer GE800, which consumes 24.4W. In Singapore, it's currently 31.72c per kWh. A GE800 would consume 585Wh per day or 213.5kWh per year. It therefore costs $67.72 of electricity per year to run a GE800 24 hrs a day all year. In contrast, my TP-Link BE230 at 8.1W costs only $22.58 to run. My actual tariff is lower at 17c because I contracted with Tuas Power a few years ago (expires next year) and I actually pay just $13 per year to run the BE230.
Running at powerful Deco BE95 mesh of 3 nodes actually costs $186 per year so these costs can add up. It's even worse than a refrigerator. My Panasonic fridge is rated to consume 249 kWh per year, whereas a BE95 mesh of 3, consumes 586 kWh. Its like running two fridges!
So those with routers that support 10Gbps. Do know that you are actually paying something like $40 a year more for your speed! Those who are frugal would do well to turn off their 10Gbps WiFi routers at night or put them on a timer. Of course, your iOT devices would then not work.
TanKianW
As long as wifey is happy enjoying good wifi coverage for her online shopping and streaming TV shows, kids pak online game with no lag and YT watching, while Daddy is having fun with his smart home and home-labbing with no disruptions....
Priceless......every month additional power consumption and donation to PowerGrid is also ok.
:LOL:
*Two "business critical" items for SG household: A/C and internet.
Henry Ng
Asus BE88U 14.2W
Asus BE86U 11.7W
Asus BE96U 15.6W
Asus BE98Pro 23.3W
Asus BT8 11.3W
Asus BT10 15W
Asus BT16 22W
TP-Link BE230 8.1W
TP-Link BE550 12.9W
TP-Link BE800 23.5W
TP-Link GE800 24.4W
Deco BE25 8.1W
Deco BE85 20.2W
Deco BE95 22.3W
Netgear RS200 6.7W
Netgear RS300 10.4W
Eero Max 7 18.8W
Velop Pro 7 9.8W
Such saying is not 100% accurate because must see which router and fridge you are referring to and must see the user's usage.
Henry Ng
:LOL:
I strongly agree with this saying as most important is the service is good to use. If keep having issues then it will be worst.
kappak
Peacemaker
:LOL:
xonix
Sure or not ? Router power consumption > Fridge ? :unsure:
kappak
Should blame on samsung manufacturing node not good.
Always cause higher power consumption.
Any chip now made by TSMC adcance node will become good.
tsammyc
That YouTuber is wrong. He measured the fridge when the compressor was running. A fridge compressor doesn't run 24 hours like a router does and consumes little electricity most of the time. The manufacturers statistics for the fridge are on every fridge with the yellow sticker with ticks.
Also, he is not using a router with 10Gbps ports. Its normal for a AC router to consume 3W, but 10Gbps WiFi 7 routers can consume up to 25W, or 8 times a AC router and if you have a mesh of WiFi 7 routers, you are clearly consuming more than a fridge
Just look a the power adapters. The EB810v is 12V5A. That's a 60W power adapter. The Asus BQ16 is 19V 3.42A, which is 65W.
sglandscape
The idle power of the fridge is usually about 40-50W for a normal sized fridge. If you've got a bigger one it'll be naturally more.
Depending on your choice of 10G equipment, each 10GBaseT port consumes around 2W, each access point consumes about 15W-20W, so depends on how big your network is.
tsammyc
I suppose it depends on the refrigerator. I know my 5 tick Fisher Paykel consumes only a few W when idle, but I suppose if you have a large one with ice maker and all sorts of electronics, it could consume 40-50W. How many ticks does that 40-50W consuming fridge have?
If you look at Dongknows website, he puts a power meter on all his routers. The ones with 10G ports consume up to 10x the power of simple routers with 1G ports.
sglandscape
Unlikely to be 10x unless you're talking about POE or support for even higher speed. For 40-50W it's 3 ticks. You would need to measure the fridge over the day then take the average, can't take the point in time where it's doing nothing.
Usually there is a defrost cycle too that consumses more power than a few watts.
phayze
My network using around 250W which include router, access point, NAS, ONT, cooling, etc.
Henry Ng
You are right la, in general for home use usually the router is only 2.5w and most average users will not be that heavy use.
Henry Ng
You're running a DIY NAS?
Most Home users in HDB is just one router cover the whole HDB unit. Since it is router, access point, NAS, ONT, cooling, etc. are many devices that take up the 250w then the saying that one router more than a fridge is also not correct.
