120mm case fans
1a2a3a
Hi. I'm looking to get 2x 120mm case fans. Don't need super performance but silent matters. Don't need flashy led also.hopefully cheap also?
Does anyone have a good recommendation?
Fookai
How about corsair af or sp series?
Sent from ------------------------------------------------------- ^^ using GAGT
ahbear82
for normal PC casing, normally use 120mm fan of 140mm fans right.
any recommendation for silent high rpm, led fan? prefer those that dun use metal screw.. i have seen somewhere that it can use some sort of rubberise material to secure it..
EienShouko
Uh is there like a under $10 fan?
Under $10 won't get you quality silent fans. The $5 500rpm fans it'll get you are silent, but they won't push any air either.
For cheap fans, Yate Loon is your best option.
1a2a3a
Not really looking for performance. Just looking for something that blows and silent. Any venue to go to?
jtjt00
Cheap fans are likely to have lousy bearing, noisy after sometimes.
superzheny
Just buy a 4 pack from cooler master. Case fans are the least bang for the buck items u can buy.
