freakerknoid
- Jun 30, 2006
I know this might be damn obvious. Can I plug in a 5v RGB led into a 12v header on the motherboard or is it going to fried my led.
Yeah I thought so. The stupid me went ahead and bought a 5v without checking the motherboard. Asus Maximus ix code has 2 12 v header only...sigh
Unless u place a resistor to drop the 12V to 5V which im not sure what will happen to the LEDs.
If it is cheap, just take it as lesson learnt and buy 12V LED strips. Even if not cheap, nothing you can do except to buy 12v led strips. Lol.
Use a 12V to 5V regulator like LM7805 is better.
But PC has 5V connector too. Why not use the 5V directly?
https://youtu.be/zu9mikz9zpQ
This video will explain the differences
Basically both of them the headers have different signal. Plugging 5V rgb into 12v will fry your 5v strip. Plugging 12v into 5v will not fry it, but it won't work.
Using the msi b450 as well with a 5v rgb hub for my 6 5v rgb fans and 2 led strips
