14 inch Macbook Pro M2 for Programming
Russelly
Hello all
I am Windows User for programming and development. May I know new 14 inch Macbook pro is best for programming ?
Please share and advise.
My Programming language/Tools/Configuration
1) Docker / Kubernetes
2) Spring Java
3) Vagrant
4) Golang
5) Python
6) Ruby
7) MongoDB / Redis
8) API Gateway ( Apigee/Google/AWS) setup locally.
9) IDE
davidktw
Hello all
2) Spring Java
3) Vagrant
4) Golang
5) Python
6) Ruby
7) MongoDB / Redis
9) IDE
As long as your applications works on an ARM architecture, all these technologies are fine. If you need a linux environment, just run a headless linux VM locally will do.
davidktw
Macbook Air seems okay as well? 3K
It is all about budget. If you don’t feel you need or want to pay for the premium components like a mini led, or the 120hz promotion display, or much better speaker system. you can always settle for the MBA 15, or 13. They are all very capable machines, just not the top tier only. :)
