16GB MicroSD card found inside Note 9 when received
jAguero_
I just got my note 9 yesterday and i found a 16gb microsd card inside the phone. anyone else have this microsd card inside as well?
This has been replied plenty in the Note 9 thread. All SingTel sets come preinstalled with the microsd card.
jAguero_
PS. I tried to search but din came across replies for this qns. Ignore.
No worries. No one gave a good reply why that's the case though - so if you're concerned you can always check with SingTel. But free stuff mai hiam la huh.
Habrosus
TBH, I'd be worried to find a memory card in the slot of my newly-bought phone.
Would I dare to use it? Guess I'd want to scan it for virus first... or since it's only 16GB, I might just leave it aside and not use it at all.
ST could have handled this in a better way.
Chys
Err mine is a Singtel set but how come dun have the 16gb micro sd card huh?
