- Sep 16, 2018
Compatibility with 10G SFP+ port with 10G RJ45 SFP+ adapter.
Singtel ZTE F8648 ONR --> Ethernet cable --> 10G/2.5G switch from Hasivo --> Fibre --> Hasivo 10G SFP+ port with 10G RJ45 module --> Ethernet cable --> the above adapters attached to Acer Swift 3 laptop with Intel Core i5-1135G7 CPU, 16GB RAM, 512GB SSD.
The download speed of the WaveLink USB 3 to 5G NIC drops quite a bit in this setup. But it is a known problem.
1) 10G USB 4 / TB3 adaper from IOCrest (USB 4/ TB4 Type C )
2) 10G USB 4 / TB3 adaper from GRiS (USB 4/ TB4 Type C )
3) 5G USB 3 adapter from WaveLink (USB 3.1 Type C)
4) 2.5G USB 3 adapter from Ugreen (USB 3.1 Type A)
5) From an Intel N100 Mini PC (dual SFP+ ports, Intel 82599ES 10G NIC chipset) connected to the same Hasivo SFP+ switch using Fibre cable (as well as SFP+ optic modules).
Bash:
PS C:\work\speedtest\ookla-speedtest-1.2.0-win64> .\speedtest.exe -s 13623
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 2.03 ms (jitter: 0.15ms, low: 1.92ms, high: 2.26ms)
Download: 4708.19 Mbps (data used: 3.2 GB)
1.81 ms (jitter: 6.60ms, low: 1.34ms, high: 205.74ms)
Upload: 4977.87 Mbps (data used: 7.1 GB)
6.84 ms (jitter: 2.32ms, low: 1.11ms, high: 210.91ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/f5985d7d-8bfc-4f5b-b42e-e0e2bd4b3ce0
Bash:
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 2.17 ms (jitter: 0.26ms, low: 2.06ms, high: 2.51ms)
Download: 4837.67 Mbps (data used: 8.1 GB)
1.40 ms (jitter: 6.31ms, low: 0.86ms, high: 214.40ms)
Upload: 4980.37 Mbps (data used: 6.9 GB)
7.17 ms (jitter: 2.51ms, low: 1.42ms, high: 216.41ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/94571e88-1dfe-4ff3-bd10-1a0b1a8d5774
Bash:
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 1.83 ms (jitter: 0.59ms, low: 1.29ms, high: 2.13ms)
Download: 2828.70 Mbps (data used: 5.0 GB)
16.53 ms (jitter: 37.59ms, low: 1.01ms, high: 249.72ms)
Upload: 4537.62 Mbps (data used: 5.6 GB)
7.27 ms (jitter: 0.88ms, low: 2.68ms, high: 17.13ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/93b2993d-7469-446b-8eb0-76dc69b1e8f5
Bash:
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 2.76 ms (jitter: 0.32ms, low: 2.33ms, high: 2.89ms)
Download: 2170.15 Mbps (data used: 2.1 GB)
1.34 ms (jitter: 3.05ms, low: 0.92ms, high: 203.96ms)
Upload: 2129.50 Mbps (data used: 1.9 GB)
12.26 ms (jitter: 1.05ms, low: 2.01ms, high: 18.18ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/b1ad980b-f6ba-4d65-b935-e40ffe01e1ac
Bash:
mcuee@miniroute10g:~/build/networking/ookla$ ./speedtest -s 13623
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 1.62 ms (jitter: 1.08ms, low: 1.47ms, high: 3.82ms)
Download: 5656.95 Mbps (data used: 5.3 GB)
1.61 ms (jitter: 3.15ms, low: 1.27ms, high: 210.73ms)
Upload: 4983.28 Mbps (data used: 6.2 GB)
6.18 ms (jitter: 0.63ms, low: 1.90ms, high: 15.72ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/21ae728d-49c9-4336-9e77-6fafc01a93c2
