Q10spy
- Jul 28, 2019
Can you buy separately at 192? Please enlighten meMR also have this router too.
Which 30 dollar Asus router is it?Hi all how flexible is starhub on using personal router? Example Asus. They offer 30 dollar for 2 years contract abit tempted to get.
My laptop with a 7 year old processor couldn't even do more than 200mbps with a wired connection. Now that I come to think of it, these 5gbps/10gbps are really too much bandwidth for most people to make use of. I think I just need 1-2gbps, i will see whether 5gbps make a difference after I get my ONT.
1. NLT Appointment for Fibre ActivationFor new signups, are there two appointment dates (NLT+Starhub) or just one? I remember selecting two dates when ordering online but in the order confirmation there’s only the later date (Starhub installation). Chat with SH CSO on Whatsapp, they also said they only see the SH appointment date on their end.
Thanks really appreciate ur writeup. Any recommendation for routers with their ont. Usually get Asus routers, this time was also toying the idea of ubiquiti. What's ur suggestion since mostly will be on wifi except for a ps5.As long as you go with the ONT option, then you should have no issues to use your own Asus router.
Take note Starhub 5Gbps offer at S$29.55 per month has two options. One with ONR + Nokia Beacon 2, one with ONT and no extra router. Make sure you go with the ONT option.
I have provided the links (ONR and ONT link) and comparisons here in the first page of Singapore ISP comparison thread.
https://forums.hardwarezone.com.sg/threads/singapore-isp-comparisons.6665380/
You need to call router manufacturer for technical support.For the starhub EB810v, I bought from them. For the router warranty, do I need to register? Or if anything wrong with it, I just call Starhub up?
I went with Alta Labs Route10, and turned my existing Asus GT-AX6000 into an access point. Downside is you need to buy additional SFP for the two 10Gbps ports.Thanks really appreciate ur writeup. Any recommendation for routers with their ont. Usually get Asus routers, this time was also toying the idea of ubiquiti. What's ur suggestion since mostly will be on wifi except for a ps5.
any existing customers recon for the $30.37 deal?
Just wondering what is this S$30.37 deal. Thanks. Any links to the deal?
The popular deal in this thread is the S$29.55 per month promotion for Starhub 5Gbps plan.
You can get usb 3 to 2.5G LAN adaptor or a usb 3 wifi 6/7 adaptor depend on OS like Windows 10My laptop with a 7 year old processor couldn't even do more than 200mbps with a wired connection. Now that I come to think of it, these 5gbps/10gbps are really too much bandwidth for most people to make use of. I think I just need 1-2gbps, i will see whether 5gbps make a difference after I get my ONT.
