2017 LG OLED
cscs3
I will politely decline to get refund and insist on C7 model.
I will wait for their offer first before any negotiation. They might have to buy from other vendor. Your best scenario is getting C8 at no additional cost :s13:
Support that. I suspect they damaged it when trying to pack the display set. I would want a replacement without additional cost. Wait for shop to ofter you, else move to another store.
celong27
They refunded me on the very same day but the store at amk is short on cash so they had me directed to northpoint instead.The manager applogies so all is well.
I took the money and bought the c7 on qoo10 from mega discount store at 2638 compare to the 2800 from harvey.
celong27
The salesman told me its the last brand new set and i had no idea how it was damage if it os a brand new set.
Microstar
In reality, how do you guys determine if the set delivered is a brand new set or one that is on display but repacked and sold as brand new? :s11:
celong27
The ku6000 is an not bad tv.I have it with me for around 3 years and it serve me well.
I suggest u buy one that have the latesr feature like dolby vision, hdr10 and the upcoming hdr10 +.Panasonic is coming out with their 2018 model soon with hdr10 + but no dolby vision becoz both panasonic and samsung is the only two that support hdr10 + while the others are going with dolby vision.
Television tech is getting more complex.
https://www.google.com/amp/s/www.fo...s-two-new-hollywood-tuned-oled-tv-ranges/amp/
think no more liao...
anyway i'm deciding between these 2..
LG 55UJ632T 55INCH UHD SMART LED TV
SAMSUNG UA55KU6000 55INCH UHD SMART LED TV
5star_pundit
Hi guys pls do not meddle with the advance settings of the OLED TV wat happened was i tried to change the country code to USA using Logitech Harmony remote to watch US Netflix but unsuccessful now i forgot to write down the local code when i wan to switch back to default so in the end have to pay $100 for LG service guy to update the firmware using a usb thumbdrive
cscs3
Good advice.
mun_hoe
salute u bro
ur heroic deed will not be forgotten
Nakedtoes
The code u cant get from net?
