malevolence14
- Sep 16, 2014
Mine 11inch WiFi version 256gb coming 7th nov
you pre-ordered once its open?
Same here, mine has shipped today too. Just trying to find accessories before it arrives but only Apple's one available now
Take note I think it will take a while for third party cases to be compatible with the 2nd gen Apple Pencil ...
Apple casing is nice but too ex.
You pay for the quality and design.
I know engraving is free but is it important? My fren said it’s important as it serves as a form of identity and may be useful info if stolen. True?
I won’t recommend engraving too. I had an old ipad with a symbol engraved - not even identity, very poor resale value down the line, macham like worse than scratches.
https://www.hardwarezone.com.sg/review-apple-ipad-pro-2018-review-apples-notebook-killer-here
HWZ Review...really need to find better writers man. The one point that screams out at me comes at the end.
"I haven’t had the chance to play around with it much but I did manage to import photos off my SD card using a USB SD card reader and a USB-C to USB-A adapter."
Then the change to the USB-C port is listed as a con as it has limitations? aren't you kinda contradicting yourself?
The inclusion of the USB-C port alone allows for so much more expansion and functionality. check out the review from The Verge, at least they tried with multiple dongles to see what worked and what didn't.
I think the HWZ "Review" can be a lot better.
I'm still thinking whether to get the 64gb or the 256gb...
Anyone getting the 64gb?
No, Apple has strict implementations on how the USB-C port should work and one of the restrictions is that you cannot connect external storage devices like USB flash drives or even USB external portable HDDs to it. This means that if you have to wirelessly transfer files and documents to the iPad Pro.
