2018 iPad Pro
phelios
anybody who hasn't gotten their 11.11 courts order? I ordered on 10 Nov and suppose to deliver on 13 Nov but haven't received the item nor gotten any call from them. dsmn hard to reach them also because their hotline is just a call centre forwarder and do not handle customer enquiries directly.
Overtmission
Suspended
Which model u ordered? I received my 11” 64 and 12” 256 cellular following day leh
GotBetrayed
I usually use the Documents app by Readdle to store and open my files, such as PDFs and it can be found on the App Store.
And also able to store offline documents on the iPad and it has got an iPhone app as well.
It’s pretty great and does work with Google Drive, OneDrive, DropBox, Box and a few others.
Image from the App Store
Documents by Readdle by Readdle Inc.
https://itunes.apple.com/sg/app/documents-by-readdle/id364901807?mt=8
This one is way better than files app imo
phelios
ordered the 11" 256gb wifi leh. until today nothing heard from courts. their hotline also useless, the operator say they only forward enquiries or issues, they dont deal direct with customer.
Halo green
interesting.What does this do that Google drive can’t
iguoh
I received one call which informed me that there is no stock and that they will call me again. Since then no more calls or SMS.
Posted from PCWX using Pixel 2 XL
tec_geek
The app is mainly used to store documents and files offline/locally on your iPad.
You can also transfer files from a PC or Mac to the app, either via iTunes or wirelessly, as long as both the iPad and the PC/Mac is on the same Wi-Fi network.
This app allows you to have access to offline and online documents, so you can view them all in the one app, and not having to switch between 2 or more apps.
And also it allows you to upload and download documents from locally and online respectively, to/from Google Drive, Dropbox, OneDrive, Box and a few others.
jasonlimqs
I used Facebook messenger to contact Courts.
Gave them my order number. The next day received call Liao.
12.9" 64gb wifi delivery on Monday 19th Nov.
Maximus_XXVIII
thks ! i am using this 6 port anker charger, its a hassle for me to have a stand alone charger just for ipad pro. I try out and see how slow :)
Tested on my Aukey QC 3.0 charger with a USB power meter and it basically charges like a normal 2.4A-5V USB port without any fast/quick charge function.
Got myself a Anker PowerPort II, which comes with a 30W USB PD port and a 19.5W PowerIQ 2.0 port (similar to QC 3.0). Can use for both Apple and Android devices:)
tessss
Have you guys tried to use the SanDisk USB c otg thumb drive on the new iPad pros ?
Can import and export files on the iPad?
tohchr
Answer is USB storage not supported. Except for example, camera plug in, it will allow u to import photos.
tohchr
Can we use the same USB adapter for MacBook on iPad Pro? Wanted to extract some photos from SDcard
As what adiboy explained, u need a 3rd party app to use USB reader. U can find those app in the App Store but I think u red to buy their adapter to read the USB card. Something like that.
