2018 iPad Pro
melankholy
Bought a usb A to usb c adapter, thinking of using the original UsbC cable and this adapter to charge the iPad Pro 12.9”.
But don’t work.
Went to challenger and tried another 2 usb a to usb c cable of brand Hoco and cannot charge at all.
Then Customer service recommended Mazer(sg designed)
Able to charge the iPad Pro.
Had the same issue as you. Bought an Omar's cable but couldn't charge the iPad. Unfortunately for me I ripped up the box so couldn't do a change.
hmsweethm
U face the same issue too?! Wonder how they pass the quality check.
Quite shocked that the cables don’t work.
So for the rest, better test the cable on the spot so that u don’t need to make another trip back.
melankholy
I think it's a known issue with usb-c. I watched a video where they say that usb-c is the name of the shape of the connector. But the connection/circuit inside is varying. That's when you will get issues like cheap cables unable to charge ipad
Parka
Wah...contrary to the bro who said cannot...
Any reliable sources to confirm?
I have Apple Pencil 1 and 2. The tips are interchangeable. They have same shape, size and screw thread.
Only difference is Pencil 2 tip is matte surface and Pencil 1 has slight gloss.
audioenslave
Thinking to let go my apple pencil 2 and smart folio case 12.9” 2018 frm apple since did not get to utilise it much..anyone keen can pm me
alan_shearer
Bros anyone has problems connecting “older” Bluetooth devices to the new iPad Pro?
I have a Logitech R500 remote presenter that worked with the iPad Pro 10.5 (Bluetooth 4.2) but it cannot pair with the new iPad Pro 11...
Anyone has experience ?
0400392G
Me too. The same presenter. I thought was a problem with my logitech presenter. Worked with my older ipad pro. Am glad I am not the only one.
Wonder if there is a solution to it
laughingPANDA
Thinking to let go my apple pencil 2 and smart folio case 12.9********* 2018 frm apple since did not get to utilise it much..anyone keen can pm me
Wow that's fast. Don't want to keep it awhile longer to see whether you'll use it?
Posted from PCWX using Posted from The Panda's Lair
alan_shearer
Wow, that means it’s really the Bluetooth compatibility. Sucks man...time to look for a new presenter cause I ain’t going back to the 10.5 because of this...
What about you bro?
deathst
alan_shearer
Found a “temp fix” bro. Use the Apple USB-C to HDMI adapter that has a USB-A port. Plug the USB adapter from the Logitech presenter into the USB-A port. The presenter will work now although not via Bluetooth but via USB.
Works for me because whenever I am presenting I always bring the Apple adapter along to connect to HDMI.
RT_3135
Has anyone tried using the 29W or 30W charger to charge the ipad pro 2018 12.9? Is it faster? I am considering if its worth it to purchase this charger from apple for fast charging. Thank you.
dlubis
Should be. Currently I'm using 61W or 87W from my MacBookPro, for sure it is a fast charging. Just hoping the battery is ok with such big chargers.
sillyb0y
Where can I get the good glass protector and the shop will help to paste? Apple shop got provide pasting service?
laughingPANDA
I'm also using my MB charger to charge the iPad. Hopefully the battery will be fine hahah
Sent from The Panda's Lair using GAGT
Glariel
Apple store don’t provide pasting service. I asked when I got my iPad replaced 2 weeks ago
