2018 iPad Pro
strezzor
Hi all. Can I just check if anyone is experiencing a ripple effect on their screen when using the apple pencil and is this normal? I noticed that I get ripple effect when taking notes on the GoodNotes app.
runforyourlife
Moderator
Moderator
I’m thinking of buying a 11” pro in 2 weeks time.. wonder should I buy online and get points off rewards card or go down and get 2-3% corporate discount haha.
runforyourlife
Moderator
Moderator
Guys, I’ve bought the 11inch iPad Pro.
Bought one Anker charger with pd USB c, and 4 USB ports and it doesn’t charge the iPad Pro. Kept flickering without charging damn it.
Can u guys recommend a multi charger for the following?
- iPad Pro
- iPhone XS Max
- other USB devices such as Garmin watch
Thanks!
zheyan
I'm currently using Hyperjuice.. 👍🏻
- iPad Pro
- iPhone XS Max
Thanks!
laserzx
I just bought Anker PowerPort Speed PD 5.
I am able to charge :-
  1. Ipad Pro 2018
  2. Iphone X
  3. Iphone 7 Plus
- iPad Pro
- iPhone XS Max
Thanks!
foxriver
11” or 12.9” model? Intending to use for school / note taking, will be getting pencil.
12.9” too big for carrying around?
Windowlover
If you intend to bring around everyday, get a smaller
version is best.
Bigger screen is good if station or at house maybe.
foxriver
version is best.
Anywhere else to get the iPad cheaper than retail? Courts / gain city / challenger?
Looking at the price from Apple directly is 1639 if I’m not wrong for 11” 4G 256GB.
Since getting the pro, should get Apple Pencil 2 right instead of 1 😂
deathst
The current pro only works with Apple Pencil 2. 1 is not compatible due to the lightning connector. The 2 uses Bluetooth to pair not vi the connector.
deathst
chonwin
My laptop does not have USB C port. How to connect the Ipad Pro 2018 to laptop to use iTunes. Thanks.
