Tried and went back to film..anyone using tempered glass? may i know your brand or recommendation thanks!
Recommend to avoid it.anyone using tempered glass? may i know your brand or recommendation thanks!
The ipad screen will flex a little. The glass screen protector may cause some issues with it flexing when pressed on.
Sent from Samsung SM-G975F using GAGT
anyone recommend a C coder app? taking some lessons using skillsfuture credit, but i only heard of phytonista?
there is no app for coding in ios because you cant execute code ?
Who told you that? LOL
Try these apps "C-programming language for os", "Learn to Code with C++".
Just get the Power Support Matte Screen Film. You won't regret it.
where did you buy? thanks!
As a student. You will need the Macbook still. There are things that school uses that websites that are so dated that it does not do well with touch input. These are legacy systems that still exist that roots down too deep to change easily.
iPadOS certainly helps but the sites are still not as comfortable to navigate at times.
Using Nano Tech -Matt Tempered Glass.
Loving it so far, don't have to deal with finger print, anti glare.
Only con is the screen looks just a tiny bit grainy which I find its worth the trade off.
I’m using the same as well. Except for the grainy, i think it’s alright for the price.
What's the promo and damage?after thinking for a few weeks, i finally bought the 12.9" ipad pro from Best Denki at Ngee Ann City.
they're having some promotion now, free case/screen protector/k380 logitech keyboard and PWP 8% off apple pencil.($173)
Does anyone know if Inateck cases are available locally?
Specifically, this one> https://www.inateck.com/inateck-kb0...12-9-inch-keyboard-case-for-2018-3rd-gen.html
