2070 Super running hot in custom loop - help
c0ke123
Hi need some advice from the water cooling gurus
Just upgraded from 1080 to a 2070 super in my custom loop
Prior to this my gtx 1080 ran at full clock speed with at the 60c range under full load in Heaven.
However in the same test, with the 2070 it runs at 83c @ 1000mhz clockspeed?
Is this normal for it to run at such low clockspeed and high temps in a custom loop? Idle is at 45-50c
Could it be a faulty card or something else? Cpu temps are at 60c under load.
Any advice is greatly appreciated.
Pics link below
http://imgur.com/a/Cq8naM3
https://imgur.com/a/rQVuiRc
Koenig168
or forgot to remove sticker from CPU block?
(I've done that before :s13:)
c0ke123
aaragore
make sure ur gpu block is screwed in properly, ur idle very high also sia...my 2080ti doesnt go above 59 on full load and idles at 31
c0ke123
Just to put it there, im using a Nzxt Manta case which is a slightly oversized itx case.
I have 1x 280 rad and 1x 240 rad in push config.
Ran fans(ek vardar) at full speed but to no improvement.
So I would say the limitation is not on my case or loop right?
It boils down to the gpu block that it could be defective or something thats not transferring out the heat right?
aaragore
ur case, fans and rads are sufficient for ur specs, i would still take a look at your gpu block considering your cpu temps are really good
c0ke123
here's the ss of msi when running the test
