yusoffb01
- Jun 17, 2008
theres no lowering of expectations by using nonx3d cpu. 5070ti is good can max out 1440p.I might consider lowering my expectations and go for a 7700 with a 5070 Ti, if that combo fits within my budget. Honestly, any upgrade would be a huge leap from my current setup. Do you think 2K SGD is a decent budget, or would it be better to stretch it to 2.5K? For context, I don’t plan to upgrade every 2–3 years, more of the type to use the PC for as long as it lasts.
As long as you stick to 1440p, you shouldnt need and upgrade
