35C mb temp on load: normal?
hlots123
No idea, my mb only got 2 choices, MB and CPU. Anyway I switched all to tag to CPU.
default shud be cpu already, so something must hav changed it to mb for u - i suspect aisuite since u mention using b4...
arcana75
Motherboard 35 sounds alright for me. Did you face any issue at ard this temp?
No issues.
All along set to mb, bios or ai suite. Could be due to usage of CHA_FAN2, so default setting for this pwm is mb.
Might change fan tho, 2000RPM 140mm JetFlo damn loud compared to my Fractal Design Silent Series fans.
hlots123
not likely.
if u used aisuite auto dunno wat where it optimise oc & fans etc, more likely it made changes u just didn't realised
Krabs.
I only know when skylate just released late 2015 ... aisuite crashed on many users ..... heng ah I didn't install it
twlee88
Biang.. MB temp high, people worry, MB temp low people also worry... :s22:
i literally lol'ed :s13::s13:
my lian li case even worse..and cpu stock fan spoil somemore...get new fan only spin until 2k 3k rpm?
play witcher 3 can auto shutdown..so now only play dota 2 nia :s22::s22:
waiting for gpu worth upgrade and change all over agn..its been 2 years
hlots123
u & moneyface completely misunderstood his concern abt mb temp being at 35c, dunno how dunno why... :o:o
twlee88
no la. im not lol at TS post. i just lol-ed at moneyface statement coz its funny and spontaneous.
and by the meaning of lol is really lough out loud...not sarcasm type of lol..
apologies if it convey other meaning =:p=:p
MoneyFace =p
Well i did not mistaken his concern. Im just stating there is no concern for his MB temp to be this low LOL.
My ASUS P8H67-M PRO motherboard at home is reading 27C.. Is that abnormal? :look:
hlots123
i oso talk talk only but i realise my posts usually appear curt, tats why i try to include smiley so less misunderstood (not succesful!)... :o
arcana75
not likely.
Think u're right. Previously play with settings under BIOS, QFan, etc, I dun recall being able to choose the sensor, but once I installed AI Suite, and pressed Optimise, it must have changed, cuz it also did a fan optimisation step.
hlots123
yah, but to expand on this...
in bios if u use the qfan control shortcut at top of uefi page, it only bring u to the graph part where you can't select peg to cpu/mb/etc
hav to goto the "monitor" section of bios, dig down abit more then can find the peg to cpu/mb/etc...
kiv the step up/step down delay quite useful if the case fans rev up too often when cpu momentarily spike... :)
