3rd party camera battery and charger
shaff12
Appreciate any help and kind advice. :):):coffee:
Is there any reliable and good brand for 3rd party camera battery and charger to recommend?
And where to get them?
For Sony and Panasonic cameras.
caterham7
different camera models may use different batteries and charger
also, some modern models now allow charging via usb, so can use your usb charger or powerbank, instead of buying dedicated charger/battery
the process to start, perhaps is to check your camera manual to see of usb charging is available
if don't have usb charging, then google search your camera model + the word charger or battery, e.g. canon m6 charger. then you should see different 3rd party solutions
then you can google those specific 3rd party model names to see the reviews for them, and whether they are available for purchase
ZhouXingXing
i dont use 3rd party battery.. for charger i use nitecore traveler charger so far so good
Nelson_Tan
I'm using NiteCore battery charger after my original charger died... pretty good with battery health readout and charging voltage read-out. My experience with 3rd-party batteries have not been good... they don't hold charge as well, and some newer cameras can detect use of non-original batteries and keep bugging you with notifications.
