5G speed and coverage
Justanewbie
Anyone using 5G regularly ? Is it worth the switch from 4G ?
How has real world experience been in terms of coverage across Singapore and the speed ?
cosmothecat
this is Singtel’s 5G
just tested
TyL3r_DuRd3n
My post on Saturday evening.
went to barrage yday.
there are heaps of people enjoying NDP rehearsal.
tested eight vs gomo.
eight (4G): can complete the speedtest albeit less than 1mbps. 4 out of 5 bars of signal
gomo (5G): could not even connect to the internet. full 5G signal btw
cosmothecat
Mobile Virtual Network Operator has lower priority when an area is crowded
go with expensive SingTel 5G plan for priority access
tomsss
when it is working, it's great
but i experienced many times, i see my phone connected to 5G and no data movement. I had to on off airplane mode then it works
Hello_Kitty
i seriously can't feel any difference between 4G and 5G for my activities such as listen to music, texting and youtubing
70niner
I find my battery life draining very fast when on 5G
Personally I dun think the increased speed is worth the deterioration in battery life
shidenx
5g experience has been subpar.
You can have full bar and no or slow internet.
4g at least it was mostly smooth.
Justanewbie
no real life use case that 4G cant support
Seems like not worth the upgrade for now.
