5GbE and beyond ethernet adapters
TanKianW
Just a matter of time for this upgrade when all ISPs start to offer 10G fibre.
Intel x710-T4L Quad Port 10GbE BASE-T NIC, pre-flash with Intel firmware straight from the vendor. 4x 10GbE, support for 1G, 2.5G, 5G and 10G.​
hoaaron
Just sign up for M1 10gb, looking to upgrade my PC network card.
Thinking to get Wavelink AQC113C-B1 Chipset, PC currently using MSI B550 Tomahawk mobo.
How's the temp for Wavelink AQC113C-B1 Chipset, or is there any alternative recommendation?
Thanks in advance
guangzong
I am using the Intel X710-T2L. It runs cool and well. But on the latest GT-BE98 firmware, it refuses to negotiate at 10 Gbps, and can only connect at 1 Gbps :ROFLMAO:
Searched online and couldn't find any solution, so i resort to using the Marvell AQC113.
HexenHeretic
I'd just stick to RTL8126 on windows desktop for now, until the 10GbE gets better/mature enough on windows to be stable.
guangzong
Latest GNUton firmware released on 24 May does not seem to help.
If i connect a 10 Gbps switch in between the ONR and GT-BE98, the Intel X710-T2L can negotiate at 10 Gbps.
ONR (10 Gbps LAN port bridged) -> ASUS GT-BE98 -> 10 Gbps Switch -> PC. Result: PC NIC negotiates at 10 Gbps.
ONR (10 Gbps LAN port bridged) -> ASUS GT-BE98 -> PC. Result: PC NIC negotiates only at 1 Gbps.
I was on 3006.102.3_1-gnuton0_beta1. I upgraded to 3006.102.4_1-gnuton0_beta1 (released on 24 May) - it didn't help.
If i downgrade to the much older 3006_102.2_2-gnuton0_alpha1, issue goes away.
Intel X540-T2L and Marvell AQC113 do not exhibit this issue.
Conclusion: the new firmware branch does not seem to work well with Intel X710.
Fronsac
Thoughts on this $50 10gb card?
Fenvi AQC113
I have 2 AQC113 card, both of them have the same issue with overheating and the network card will get stuck, looks connected but no traffic will be sent or received. So I kind of against recommending any AQC113 card at the moment. Mostly triggered by high traffic volume so I suspect it is overheating, I think my setup is partly to be blamed since the only slot is right next to the GPU so it will be very sensitive to heat. No such issue with the realtek 5G card.
My AQC113 is Asus and TP Link, looks similar to me.
guangzong
I have the same issue under heavy load. Try turning off Recv Segment Coalescing (IPv4) and (IPv6). You will find users with similar issues on Reddit.
Fronsac
Yeah already tried all the different combination and all of them will get it sooner or later. So I just buy a 5G realtek slap it in to use until i can be bothered to fix it.
Lehnsherr
Got one question where to get a SFP+ NIC locally?
Going to use it with a Ubiquiti DAC, then connect to a Ubiquiti gateway
thanks
Fronsac
DAC is directly connected to the SFP port on both device so there is no need to buy additional.
Lehnsherr
Yes I mean a network card that comes with SFP+ instead of the typical RJ45
like the many examples tht has been posted on this thread
morimorimori
10gtek used to have shoppee store but thats closed now. Gotten others from ebay. Intel X520-2 in nas, desktop has mellanox 311a.
Lehnsherr
cj2502
Saw the Fenvi card being mentioned earlier. In case anyone is looking at it, its working very well for me.
Stable connection, no dropped packets so far. Good speeds too. on M1 6gbps plan. BE805
