650D Vent Fan not working!
Hello_guys
As stated above, my front and back case ventilation fans are no longer working.
Only the top 200mm fan is still spinning at a slow rate. lol.
Used to be able to turn them on using the fan controller, as i did not fix this pc myself, i do not know how to fix it.
Probably any owners of the same casing can advise me what to do
shadow84
Try plugging the fan into ur header of ur mobo. If it spins, it means the header of ur fan controller is damaged. If it doesnt, it means ur fan is dead.
If so, jus get a new one.
Since its ur com, shld learn how it works.
Hello_guys
hmm.... ok. thanks. dont really know how to go about doing it, good time to start learning though
