$750-$850 PC Build HELP
eugenetdr
hey guys, im trying to build my own rig but i don not know if it will work out. could you guys help me rate it this build build is good enough. my main purpose is to have some casual gaming (fps games and minecraft xP), watching videos and most importantly downloading many stuffs. i download things such as videos (movies), games and stuff. i usually download big files and it takes time so i need to have a pc that multi tasks well. don have to worry about my 500 gb hard disk below, i have external storage.
My Intended Build:
Motherboard+CPU: MSI H77MA-G43 + Intel i5-3470 3.2Ghz $368 **PREFERRED**
OR
Motherboard+CPU: Asrock H77M Pro4-M + Intel i5-3470 3.2Ghz $370
OR
Motherboard+CPU: AsRock Z77 PRO 4 + Intel i3-3220 3.3Ghz $328
RAM: 4Gb PC3 12800/1600 KingstonCL11 ValueRam $43
VGA Graphics Card: Sapphire HD7770 1GB Vapor-X $179
Internal Storage: Seagate Barracuda 3Gb/s 7200rpm 500Gb $72
Power Supply: CM Extreme 2 525W $69
DVD Writer: Samsung SH-224 24x DvD+-RW $24
Casing: CoolerMaster K281 ATX Casing $69
Total:
1) MSI h77 + i5-3470 build $824
2) AsRock h77 + i5-3470 build $826
3) AsRock + i3-3220 build $784
i've read that z77 more suitable for overclocking but i chose the value ram as if i were to overclock, i will only overclock the i5 cpu to 3.6Ghz as it is stated that i5-3470 cpu can be overclocked to 3.6Ghz. i've also read that i3 not very suitable for gaming hance my preferred build is the MSI + i5 build. as for my vga card, i think its decent enough for gaming and price is reasonable hence i'll stick to that card. so thats all, can somebody help me to rate my build?
quekghi
ts, the up to 3.60ghz need not be 'overclock' as it's Intel® Turbo Boost Technology. it will overclock 'itself'. there is no need to overclock for your usage.
coolermaster n200 - $52
thermaltake smart se 530w - $75
asrock b85m pro4 + intel i5 4430 - $361
kingston ddr3-1600 cl10 8gb - $77
powercolor hd7770 1gb pcs+ - $167
toshiba 1tb - $80
24x dvdrw - $24
total: $836
Gyunikuchan
For that price point and the intention for gaming only, amd might be a better bang for buck... Intel processors is better for heavy duty stuff like content creation.
quekghi
that is if you intend to use onboard graphics.
nippp0n
CPU & Mobo: i5-3450 & Asrock B75M-DGS @ $291
Ram: Kingston 1600mhz value ram 8GB @ ~$76
ODD: Samsung DVD RW @ $22
HDD: Hitachi Deskstar 500GB @ ~$60
GPU: Leadtek GTX 650 Ti @ $199
Case: Sharkoon T5 @ $63
PSU: Seasonic S12 520W @ ~$78
Total: $789
Buy and build at Tradepac.
Tradepac offers the cheapest price but newbies have to be aware of their zero after-sales services and ALWAYS check your items before leaving the store. Lastly, don't be swayed to upgrade and buy more expensive components which you don't require.
