90 Degree Inverted PCIE Power Cable
RocketAbyss
Hi there,
Does anyone know if there's any shop in Singapore that sells a 90 degree inverted PCIE power cable adapter? The only one I can find is from a US site and they dont ship internationally, and I'd rather not use comgateway/vpost for just two of these cables. Thanks!
jtjt00
Try Worldwide Computer at 5th floor facing lift, SLS.
RocketAbyss
Spent the whole afternoon today looking at shops from lvl 4, 5 and 6, and not a single one of them has the 90 degree flat PCIE adapter. Does anyone know another shop that might sell/make such a cable?
Ah Ken
Hi all, bring up this thread again as I happen to be looking for one as well. Apparently this kind of 90 degrees cables are not even easy to find except for those cable mods from US.
May I check if I can just cut the plastic connector? I think the metal contacts should be deeper right? Won't get affected?
