KleoZy
- Jan 1, 2000
Hi all,
like to check if there are any shops at SLS that sells or specialize in selling fans?
it will be great if anyone of you can recommend some good fans too. This is what I need.2 x 140mm Static flow fans for a water cooling radiator and 3 x 140mm Air flow fans for the case itself. As Quiet as possible. Btw, no RGBs. Thank you in advance.
