About cmos battery
Trans-Am
1) Anything to take note when/after changing Cmos battery?
2) spec - - - >
What is my battery model & where can I buy it?
Sent from A universe Where pink PWNED everything using GAGT
tigerwoods
2) spec - - - >
Why dont you just look at the existing battery model in your motherboard instead of asking.
Clearnfc
Is your pc diy?? Also what board?? Many Mitx is not using button cell. Still cr2032 but the wire and connector is tag welded to the battery. So you need the whole module.
Trans-Am
Because :
1) I need to shift a lot of things( fan, table, etc)
2) I might need to un-mount some pcie
3) everytime I shift my cpu and then shifted it back, 98% of the time my ram will become "loose"
shadey
Because :
Loose RAM???? You have bigger issues then
Trans-Am
Trans-Am
Loose as in not tightly secure in the ram slot due to "vibration" from shifting
Rashkae
A little wiggle is normal but it should not lead to undetectable RAM/memory errors.
