Stealth_PL
- Dec 6, 2008
I am planning to build a 4K gaming pc with 7800x3d cpu
My budget is under $4k
I was quoted the following component
AMD RYZEN 7 7800X3D 4.2GHz 8CORE/16THREAD
MSI MAG B650 TOMAHAWK WIFI AX ARGB
COOLER MASTER MASTER LIQUID 360MM COOLER
G.SKILL TRIDENT Z5 NEO RGB 6000MHZ 16GBX2 32GB CL32
SAPPHIRE NITRO+ RX 7900XTX GAMING OC VAPOR-X 24GB GDDR6
CRUCIAL P3 PLUS 2TB GEN4 NVMe M.2
SILVERSTONE DA850-850W 80+ GOLD
LIAN LI O11 DYNAMIC EVO CASING
10 X120MM LIAN LI AL120 FAN
$3750/-
I know this built fits right within my budget but I would like to check with the expert here if the components are optimal for 4K gaming purpose and whether the price is reasonable for this built.
thanks for your time and help
$3750/-
