Advice for Budget Car CD Player
Nipponho
Hi,
Forgive me as a noob. My friend’s car CD player/receiver is spoilt and he ask me to help source for cheap one. He is not audiophile. As long as got sound come out, means OK already. No need DVD, simple one will do.
Present one is JVC KW-XC405
Voltage : DC14.4V
Grounding system : Negative ground
Allowable Operating Temperature : 0 to 40 degrees
Installation Size : 178mm X 100mm X 158mm
Set size : 178mm X 100mm X 175mm
Mass : 2.3kg
Questions :
1) To ensure that the new one can fit, do I take note of the installation size, set size or 1din/2din?
2) Any recommendations of pioneer or JVC or Sony or Alpine from Mustafa? Basic one, as long as can work and last.
3) I heard it is possible to go to Singapore workshops to buy from them second hand ones including installation. Is this a good idea? Any such workshops to recommend?
4) Any workshops in Johor to recommend purely for installation? (as purchase is still cheaper at Mustafa).
Thanks in advance for your forthcoming advice. :)
Leave No Men Behind
Buy sg.. yes.. then go install jb.. later I put photo of shop.. I did at 60rm... conversion. Only 20 sgd. .sweet and cheap..
yanbros
Just look for sg garage Edwin. Less than $100 can get a good pioneer system.
CCCustom
I find it ridiculous for anyone to suggest to go JB to install ...
Basic installation for a HU is $30 at most over here. To install in JB you pay $20 to the JB audio shop ... but in order to do that you also need to pay to enter JB and pay to leave JB ... add that all up and how much does it cost? Good ... now add the time loss to go to all that trouble, then ask yourself, what did you save exactly? :s8:
P.S. Installing your own HU is almost as easy as installing a DVDRW drive into your computer actually ... just the part of splicing the harness wires which isn't difficult at all since all the wires are universally colour-coded, just takes a bit of time if you're a noob.
Nipponho
Yeah, i fully fully agree with you that if someone drive in to johor just to install the head unit, confirm bo hua. The petrol and the time. I think entry also cost a few dollars. I also wonder why those ah sohs are so fascinated with ringgit plunge. Although they could buy more with the same money, but for groceries, cannot keep long, so cannot buy too much too, and petrol cost would have eroded all savings.
For my friend's case, it is OK, because he likes to go there jalan jalan, shop shop, eat this eat that, and meet chew hoo his friends for lunch. For installing HU alone, of course bo hua. But for servicing radiator, change engin oil, change seat skin, air con service, these will make quite a fair bit of difference.
Yeah i also think it is not difficult if i am determined enough. If it is my own car, i will surely DIY. But for people's car, better not. Got to force open the panel, and i never done it before, what if i scratched the surface? Plus i got to figure out how to install. I got better ways to spend my time. Now i have problems figuring out how to change motor of home fans. I see a lot of people throwing away fans. How nice if i know how to change inside motor, then i will be able to collect these discarded fans, and go sim lim tower to buy cheap cheap motors and replace, and then either use it myself, or give away to friends and relatives or low income neigbours. Even if it last for another 1 year, it is still worth it.
