Advice for PSU cables
basraghoul
So im planning to get a 4070/4070super soon, but im not sure if my current PSU
(1) have enough power and
(2) does it have the necessary cables for the new 4070s.
***this PSU is ~3yo, bought in 2020 then RMA-ed to a brand new one in 2021.
this is my current setup:
PSU: Corsair RM Series™ RM750 — 750 W fully modular (exact model here: https://www.corsair.com/uk/en/p/psu...lly-modular-psu-uk-cp-9020195-uk#tab-overview)
CPU: i5 13600kf
MB: MSI Z790P WIFI
RAM: ADATA XPG lancer 16gb x2 ddr5
KleoZy
Should have include 12vhpwr to 2x 8 pins inside the graphic card. So he can use back his current 8 pins from the psu.
true. but I for one will never use adaptor.. I prefer direct from PSU to component. having adaptor will drop current. Anyway up to individual comfort.
wwenze
Heng I don't even use modular PSU, my cable soldered straight to PSU pcb, having connector will drop current. Anyway up to individual comfort.
TanKianW
Heng I only use 2U server redundant PSU, my cable is not just soldered str to PSU PCB, there are also more solid state capacitor than consumer PSU, my PSU generally one dies or drop current another just takes over.
Anyway up to individual comfort. :ROFLMAO:​
Phen8210
dont worry too much unless using a few meter length cable in the chassis for some reason :ROFLMAO:
tsteo77
Modular or non modular psu, best is to get those non or individually sleeve to mount decent amount of
Clip-on Ferrite Ring Core RFI EMI Noise Suppressor in side the main cpu cables. Foe A healthly computing.​
Outramkia
How does the ferrite rings make me healthy?
