Advice for rig
Zeconic
Hi,
Budget of 1.2k for rig for photoshopping. Require monitor and OS.
Please advise, thanks!
ryuxdragonx
View image: 1 (MyNextCom)
+ Monitor Dell S2340L 23inch IPS panel ~ $215 (Tradepac)
if you are a light photoshop user can drop the graphics card.
Total $1210
If you're gonna be using it for some serious work or you expect to handle huge files, use i7 instead of i5. More ram can't hurt if you got space in budget, or KIV for future performance boost
