Advice needed for Cable Broadband Router
lazypigx
Hi everyone. I have a cable broadband plan with Starhub (100mbps). I only bought the modem from Starhub. The model is D-Link DCM-712. Any advice on which router is suitable/compatible? My requirement is wide range as the current fibre broadband is giving me headache on the coverage. I appreciate all your help! Thanks!
cpuer
are you keeping the fiber plan too? if your fiber is sufficiently covering one portion of your home, you want your new cable plan to cover another portion of your home?
Mecisteus
for tight budget, just get a 2nd hand asus n66u. good enough for your 100mbps. good coverage for a 4 room.
lazypigx
@cpuer Hi, I would like to utitlize botht the fibre and cable broadband to maximise the network coverage. Any recommendation on which router to get?
@MikeDirnt78 Thanks for the recommendation! Is there any option for router under $50? Asus n66u is selling near $100 at carousell.
cpuer
Assuming your cable point is where your work that need wifi, just get a second hand n56u will do. It's about $50. Choose one with warranty left, a few months also good just case you get a bad unit you still can get it changed. Its a good router for 100Mbps. 3 years warranty from asus sg.
Here got one at $30
https://sg.carousell.com/p/30946301/
Mecisteus
less than $50 is quite tight. i would recommend getting one router with antenna so that you can reach further distance.
