Will repost what I posted in another similar thread lol
CPU + Mobo : R5-1600 + ASUS B350M-A ($470)
GPU : Zotac GTX1070 Twin Fan ($609)
RAM : Kingston 2133MHz 16GB ValueRAM ($162)
SSD : Samsung EVO850 250GB ($159)
HDD : WD Blue 1TB ($72)
Casing : Fractal Design R5 ($169)
PSU : Corsair TX550W Gold ($143)
Total : $1784
Prices from PCThemes. Mix & Match with other stores/online shopping should save you some money.
OS : Carousell (<$20)
You'll have $200 left for a 60Hz monitor.
If you going for 144Hz Gaming like ASUS VG248QE, need to free about another $250-300 from the above spec. (I don't know how well optimized PUBG is, not sure what graphic settings you have to play on to get the frames needed to make use of 144Hz monitor)
- RAM can down to 8GB
- Casing can get cheaper one
- PSU can get cheaper one like FSP Hexa 550W.
