advice on replacement for CPU,RAM,MB
lee-turbo
Was using 4770k +MAXIMUS VI IMPACT + 2x8G of ram.
Recently after move house, something went wrong on mb io.
whole mb io is undetectable.
highly suspect mb issues, add on rig never shutdown for 2 years
think is time to replaced mb,cpu, ram
(pc until today still can boot to window login screen)
-verified, dp port, hdmi port, all usb port is unable to connect to any device
now looking at
i7 8700k, Lazada 479
asus z370 maximus i- 409 (10% shop coupon)-qoo10
asrock z370 gaming itx- 299 sls
G.Skill Trident Z RGB F4-3000C16D-16GTZR 16GB (2x 8GB) DDR4 3000MHz CL16 Dual Channel @ $320 - t258jgn
found that limited option for itx mb n the price is as exp as a good atx/matx board
should i consider to chg to diff form factor ?
had extra empty lian li case n secondary system, sth10 at parent's place
***system was on water cool, but these two years was running air cool, due to some leakage issues, n no time to fix
will be water cool for 8700k
next phase of upgrade will be nvme ssd n gpu
Encrypted11
You heng that someone else beta tested both of these on hwz :crazy:
[Review]Asus Strix Z370-I Gaming, small but packs a punch!
[Review] ASRock Z370 Fatal1ty Gaming ITX/ac
Also, VRM quality rating on OCN
attachment.php
In short:
ASUS: 6x20A powerstages, 1 additional M.2 NVMe, has a EK monoblock from Z270i, realtek 2x2 WLAN/BT. More RGB-ish.
ASRock: Much better VRMs (5x 60A powerstages), 2 lane thunderbolt 3.0/ USB-C PD Charging, Intel AC8260 2x2 WLAN/BT .
Both have RGB headers. But asus's version is more stylized. Had both in mind but strix-i leaning till I learnt more about the VRM quality on OCN.
The ASUS has reported VRM throttle points anywhere from 150-180W (probably case and airflow), but very few outliers of doing ~210W transient loads (throttle points from owner comments on OCN). Might be abit of a stretch since a far larger strix-f/e has some reported VRM shutdown issues ~200W CPU package power. I've personally done close to 300W on transient loads on XTU, no shutdowns with the asrock. Something to note if there's an overclocking intent.
lee-turbo
attachment.php
In short:
Read your review, but miss out the asus mb review.
Came from sandy era
Oc with 2600k,maximus e
Just feel so sad tt asus drop maximus itx mb for coffeelake
Didnt oc for 4770k much , as, once reservoir had leakage, second, mb rma
So air cool for 2 years, (busy with study)
Might need to read more n learn oc for new gen
This is attracting me
" 2 lane thunderbolt 3.0/ USB-C PD Charging, Intel AC8260 2x2 WLAN/BT "
Back then no mb support rgb controller, i am using aq6 for rgb controlling.
New gen mb is great.
Want to hoot some rgb fan for fun also.
Thanks for your advice.
Encrypted11
I came from VIII Impact, yup it's unfortunate the impact line was dropped. It would have been nice if they kept the last Z170 design, add dual m2 and moved on to the current more neutral than gamer red theming.
Outside of BIOS flashback and the abundance of beta BIOSes only for the true ROG boards, got over with the rest of the features. The thermistor cable would have been pretty cool to shove under a GPU block or so.
Z370 doesn't have high end mATXes (Gene, mocf type)/ITXes except for some very good mid range boards. So you'll undoubtedly lose some bells and whistles if you really used everything in the box.
Rashkae
Meh. I'd prefer to wait for Ryzen 2 and get a better, more power efficient system.
Encrypted11
Different ways to skin a cat though (not pusheen cat :s34:).
Without splitting hairs, the 256 bit wide vector units when used consumes a lot more power compared to the 128 bit wide vector units on Zen. But it has about double the performance of Zen+/Zen1 core when used. The stilt's Hevc decoding bench (cobra) is an example. Testing a 4 core 7700K against 8 core 1800X or even something like HWBot X265.
Others: https://deluxeforums.hardwarezone.com.sg/107337203-post51.html
Zen 2 will be interesting. If AMD doubles down on this front, does small increments in other areas, clock speeds and maintain 8 cores there's a lot to gain.
Think I mentioned somewhere, highs (power) are higher, lows are lower than kabylake. Overclocked with speedshift you're still web browsing at ~5-20 watts or so. On a full tilt like AVX2 handbrake or other up to date transcoder, 150W+ isn't shocking.
Anyway, KIV only not a representation for all uses..
Common datapoints (Best 2700X/X370 ASUS Prime on geekbench with very good VRMs vs. 8700K with spectre/meltdown patch)
https://browser.geekbench.com/v4/cpu/compare/7517979?baseline=7494872 (Stock DDR4-2133-C15-2T 95W Long/Short Duration Power Limit)
https://browser.geekbench.com/v4/cpu/compare/7518166?baseline=7494872 (5.0GHz DDR4-3200-C14-2T 200W Long/Short Duration Power Limit)
https://browser.geekbench.com/v4/cpu/compare/7518256?baseline=7494872 (5.3GHz DDR4-4000-C16-1T 200W Long/Short Duration Power Limit. Golden chip scenario..)
lee-turbo
it is always a waiting game...
cant wait anymore, past two months live wo pc, quite painful
i am so use to have a pc a home
move to new house, no pc, everyday netflix.....
Parmesean
You could always buy a nuc first, use it for a bit, then build your new system when the cpu come out...
gld998
Save your money and get a z97 board instead at lazada. Gen 4 is still relevent
Sent from Old Man Pressing For Retirement using GAGT
gld998
thought of tt but mb usually doesnt last that long :D
Ichy say ichy rah.. as if z370 board will last longer.. everything is gamble.
Koenig168
The Z97 boards there are grossly overpriced. The cheapest one there is S$285. I think you meant TB instead.
