advice on replacing current graphic card
worldofmyown
my graphic card palit gtx 560ti just died on me (i guess). tried all methods still couldn't get it to run in normal mode.
Any recommendation of which decent card that i can go with next? best is less than 200.
TIA!
bhtan83
TIA!
depends on the games u play and resolution running at.
for ur budget get powercolor 7850 2GB @$233.
qoute from tradepac. top up a bit and its more worth it.
worldofmyown
using dell 23 inch monitor. 1920x1080 resolution display. not really a heavy gamer. some light gaming whenever im free.
Teng Zai
7850 or 7770 ba, but might not play higher end games at max settings well.
7850 can handle most, below it maybe not easy.
Btw, anything lower than a 7850 is a downgrade to your 560TI. So suay died on you ah? no warranty? :(
foo9883
or go 2nd hand forum. Maybe can get 7870 or 6970.
worldofmyown
prefer first hand one eh. later 2nd hand chu pattern again zzz
i see, can take into consideration. haha. warranty just ended in may. sigh bad timing. sad
Teng Zai
Really suay lor brother. 2ND hand should be OK la. Go to blue forum see people with good rating. Even if no rating also OK, but please find those with warranty remaining, preferably 1+ years. Get yourself a good deal, if cannot find then buy 1st hand lor bobian.
One way to play safe is to get the S/N of the product from the person u buying the product from, then call up or pm distro check the S/N of that particular product still in warranty, and until when. Then when you meetup with the person, check the product S/N tally with what he tell you the first time and what you checked.
Also, check that the warranty sticker or whatever that is needed to RMA is given by the seller. Very very safe if you take all these precautions. If he give you dead GPU also can RMA :D
royfrosty
Get 2nd hand loh. 7870 should be the best bet for 2nd hand.
7850 is like just nice for normal settings gaming.
worldofmyown
7850 & 7870 v big difference? both powercolor right
true true. haha.
btw guys. will i be able to fit powercolor 7850 2GB inside my cpu?
cause there's a difference in size between my current one and powercolor 7850.
Palit GTX 560 Ti VS PowerColor 7850 2GB
188mm x 112mm VS 203mm x 111mm x 38mm (Got their size from their respective websites)
Teng Zai
true true. haha.
7850 and 7870 got difference, just like every card that is above the tier of another. But can say the difference between 7850 and 7870 is quite a big jump as compared to other card tier jumps. This is because 7870 is a tahiti card, which is base on 7900 models, so it is more of a 7920/7930 card kind of thing. However, the jump is not big until you can compare with the next tier, so it kind of makes it more of a 'bang for buck' compared to 7850. But if budget don't allow then I don't see why not just settle for a 7850, cos no matter how you see it, every card of the next tier is always better and you can never try and get the best unless you have the $$$, nevertheless, it depends on yourself and if you think the cost value is worth it or not.
And the GPU don't fit into your CPU(Processor). Unless you meant if it will fit into your computer, or more accurately said, the case of your computer.
GPU slot into the PCI-E slots, which I assume you will definitely have at least a free pci-e slot after you rid of the gtx560ti(also a gpu so using your pci-e slot)
What you need to check for is if your casing can fit it. Measure from the IO ports(input output ports, meaning the back of your casing where your 560ti ports from), measure from there until it hit's an obstacle, such as a HDD cage, then see if the card you going for next can fit in or not.
Do note that certain case, the HDD bay can remove so you can have more space for the GPU. Best to check yourself, and if you have many HDD and need that HDD bay, maybe can mod yourself or find space for it in the case.
Do check, cos these differ from case to case.
royfrosty
true true. haha.
7870 is way different from 7850.
Looking at price range and performance it should stack like this.
Gtx650ti with boost/7850<gtx660/7870
7870 might be slightly faster than 660 in certain games ba. Especially the games I played like bioshock infinite, far cry 3, 7870 performs slightly better. But I have yet to test bf3. Or perhaps I may consider getting a 770 for bf4 in future.
RockaRolla
just to clarify for the TS
theres 2 types of 7870, majority of it on the market is the pitcairn chip....only 2 brands in singapore is selling the faster tahiti le-based 7870, i.e. powercolour 7870 myst edition and sapphire 7870 XT
Teng Zai
:s13: Just realised this myself. Plus powercolor cheaper, other brand how to fight??? :(
Teng Zai
hmmmm okay haha. is it advisable to wait for coming Sept IT shows or buying from amazon?
I don't think IT show will sell, and usually IT show prices same in SLS. Sometime got promo for some items only, but many of the things either same price or more expensive :(
Anyway amazon 7950 cards about $20 more than 7870, can consider (xfx)
royfrosty
No point getting from IT shows. Now no longer see they sell parts.
Even Best bargain go there sell SSD and memory cards only.
And their price also not cheap.
Recalled 6 years back buying a 512mb DDR2 533mhz. At shop they selling $17.
At Show they selling at $16. Pui~
