Advice on small / mid tower / htpsc atx casing.
fishyy
I somehow made a mistake for buying corsair air 540 for my rig. Found it too bulky and big for my table. Nevertheless its a good casing for airflow tho.
Want a smaller and more compact one.
Those hardware components I bought also got some mistake here and there.
Abit funny and stupid la, but don't get into that later.
Here's the parts:
z87-g45 msi
wd blue
samsung evo
seasonic g 650w
gtx 670 Power
corsair hydro h80i
odd
Just listing those mains part for the measurement.
I'm eyeing on this sexy beast:
Fractal Design
Its like a home entertainment case.
Define R4 also not bad, 450D also.
One thing about the node 605 is the odd, slimline odd, whats that? Normal odd cant fit? is there any workaround or something?
Please suggest and advice, and include the pricing if possible.
TIA guys
Jian19
the slim odd only works with matx or mitx ur one atx confirm wont work
atx mobo not much choice on small cases one
