Hi
I need advice on upgrading my current system:
CPU: AMD A8 7600
MB: Asrock a88 itx
RAM: 2 X 4gb Gskill 2133mhz
GPU: Sapphire R9 380 itx 2gb
CASING: Silverstone Raven RVZ01
I gotten the A8 7600 as an entry level system and game abit on dota2 but later when the MGSV TPP came out, I added the R9 380.
However I feel like my CPU is bottlenecking the system as I watched even the potato masher from casual shenanigans can get a constant 60fps, while I feel my system should be more powerful, but can only get 40-50fps with the same settings.
http://casualshenanigans.com/2015/09/22/metal-gear-solid-v-the-phantom-pain/
If I were to have a constant 60fps for MGSV, should I try upgrading to an Athlon 860x or should I just upgrade to an i3 6100 system for abit of future proofing?
Or should I just wait out till Zen and the new Intel architecture?
Thanks in advance!
CPU: AMD A8 7600
MB: Asrock a88 itx
Thanks in advance!
