Hi,
I have a compaq cq45-121tx. Recently my laptop refuse to boot (no compaq logo show up) and have no display from the screen. It does, however, blink light above the scroll lock button and beside the caps lock in the sequence of 4 times.
I understand the 4 blinking sequence indicates that problem with graphics.
I tried reconfiguring my ram by swapping ram slots. My laptop comes installed with 3gb ram by manufacturer (2gb+1gb).
The thing is, if I remove the 2gb ram from my memory slot, my laptop will boot and everything works slowly (due to 1gb ram still in it). If I put only the 2gb memory slot in it(with the 1gb memory removed), my laptop will not boot at all.
Could this means the issue is with my ram module (i.e. a faulty 2gb ram)?
Side notes:
1) I have done a diagnostic on the 2gb ram by installing it on my other laptop (acer). The laptop will boot without any problem.
OR could this be a problem with the other component in my laptop?
Will buying a new set of ram solve the issue?
Thank you
Side notes:
Thank you
