Advise on display card problem
watzup_ken
Hi folks, quick check if anyone can advise if my graphic card is a goner? It works fine when I first install it in the system. After I installed driver and restarted my com, there will be no display.
Graphic card in question is a HD 7850 2GB from Powercolor.
Thank you very much.
watzup_ken
By the way, I cleaned the fan and heatsink, and spread a fresh layer of thermal compound earlier. Thus, I think heat may not be the problem since the fan is spinning and spinning quite fast. :s13:
yusoffb01
Yes that's a goner.
