Adware after system update help!
jason910
Hi after updating my S5 With that com.system patch it started to get a lot of unwanted ads spams etc and I cannot seems to clear them. I need help on This and last resort will be to reset which I am not keen. Appreciate any form of help here thanks a lot.
I googled but cannot find any viable solutions.
renfred89
You might wanna try the antivirus engines u can find on play store. If cannot, then u need a reset already..
mun
How about go to your Smart Manager, select Device Security and click 'scan device'. Hope this helps.
Good luck :)
