Aesthetic first 2k gaming pc
Allanlee82
D-day is today. Otw to doraemon's place first then to simlim! Still dont have the OS though. Might get it from g2a. Any other options?
reddit 25 usd or qoo10
i got it from qoo10, after the coupon discount and cc rebate, around 19.90 sing dollar for windows 7 pro. than from there update to windows 10 pro
moleman4eva
Thanks bro. used a 10sgd coupon and made it to 26.90
On a quick update, Bought all my parts an assembled it today and ran into 2 problem. including the 3 included fans and my h60, i need a total of 5 fan headers but my mobo have only 3. What must i buy to fix this? The commander mini looks nice but its wayyy expensive.
Next problem was I didnt have a display port cable to check the pc out so I need to head down to sim lim tomorrow to get the cables. Everything turned on though so thats a good sign :)
trento
u can use deepcool fan hub. connects to yr mobo fan port giving u 4 extra ports. can get it from pc themes.
jarred1223
use this? psu molex connector to fan. but it means the fan will run at full speed all the time.
or buy fan header splitter
trento
Don't think that's a good idea. Might overcurrent the header and cause the fan header to burn out. Worst case scenario, whole MB not working.
Only use the deep cool hub using psu via molex - 4 pin adapters.
Sent from Huawei NEXUS 6P using GAGT
Yea forgot to add not to exceed 1A. For me, i use 2 led fans or 3 non led, not all 4.
Or simple way use a one to two split, if i call it right. Noctua fans come with it.
moleman4eva
My problem is this. Bazooka has 3 headers all day. 1 cpu and 2 system. One of the system header smack right in the middle. Hard to hide the cable sio like that. I have 4 fans and one aio cooler head in total. How do i go about this? Heading to sls now. One stop away
moleman4eva
So i ended up buying 2 depcool hubs. one for each header. Basically each hub powering 2 fans. Now im stuck at installing the bloody windows. Cant seem to find the drive when installing
On a side note
All that is left now is for me to fix the led and wait for my custom cables from icemodz.
trento
U may also find an issue fixing the cpu cable. Routing it from the back requires removing the 3.5hdd cage
