Aftermarket cooler?
FatalityV
Looking for an aftermarket cooler - going to be doing heavy encoding work for quite a few months. My cores are at 63~64degs at least at 100% load, and I'm looking to lower the temp.
Not looking into watercooling - can anyone suggest a suitable aftermarket cooler for my specs ->?
Budget around 50~70.
terence52
63-64C is actually pretty good for a 3470 on a stock cooler.
Anyway, if you want to get a cooler, a Xigmatek Gaia @ $39 would do.
watzup_ken
Precisely my thoughts. The temps look really good, and is nowhere near the critical level. To be honest, there is no need to change your stock cooler if you are not overclocking, and when the temps under load looks perfectly fine. But then again, the $$$ is yours, so you have to decide. Cooling it any lower won't make any difference.
FatalityV
63~64 is pretty good at 100% load, but if I keep it running at 100% for a long time would that have any negative effects? :/
Cryogenist
Save your money..
Since already say it is at 63-64 'C at 100% load, means it will not increase more than that.
63-64'c are really nice temps way below the thermal limits.
ghillie
Naw the chip was made to tolerate such temps. I reckon ur hdd will go byebye b4 ur chip
