For using an end-frame with the same environment as start-frame, if the end-frame was edited using NBP, then the pixels won't align between the two frames.
One way to combine the two clips, is to use Mix from CapCut, and set non-uniform scaling for the second clip (101% width and 102% height).
There will be a slight non-noticeable morph but overall should be ok.
Please refer to our Community Guidelines and Standards and Terms and Conditions for more information.
