Air cooling recommendation
DellGTX960
hi all,
am currently using corsair h60 and would like to changed to a non-towered air cooler which is comparble or better.
is the noctua c14p better?
ragnarok95
Senior Moderator
Senior Moderator
hi all,
You can't find a C14P now if i'm not wrong. Current are C14S which can only mount 1 fan.
Anyway, honest opinion here you can consider. I used both H80i GT and the C14P. Both setup i am using noctua iPPC 2000rpm fans on them. Yes, the C14P is a bit better in term of idle and load (not stress test 100% load).
End of the day, i dump away my H80i and went back to C14P.
DellGTX960
you are right...c14p no longer available. any comment on the S series?.i presume is much better than the h60 since its better than the h80 at normal load
DellGTX960
looks good...i saw mix reviews between l12 and h60. anyone can comment the comparison?
